RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   WHAT FUEL!!!!!!!!! (https://www.rcuniverse.com/forum/arf-rtf-75/3676335-what-fuel.html)
muddrunner1968 12-21-2005 01:15 AM
WHAT FUEL!!!!!!!!!
what would be the best fuel to run in an os .46la/ what percent nitro and what percen oil !!!!!!!
exeter_acres 12-21-2005 07:59 AM
RE: WHAT FUEL!!!!!!!!!
any 10 or 15% nitro would be fine... most aircraft fuels have 18% nitro...
I use Powermaster 20/20 in everything...
MinnFlyer 12-21-2005 08:53 AM
ORIGINAL: exeter_acres
I think he means 18% oil.
That engine doesn't need a hight nitro content. 5% will do fine, 10% even better, but You don't need to go higher than that.
Just about any of the top brands will do very well
Look into Cool Power, Omega, Wildcat etc.
exeter_acres 12-21-2005 08:56 AM
Yikes!!! Sorry...pre-second cup of coffee post! [:@]
Yes...I meant 18% oil
and agreed, with the LA, 5% would be fine...
I don't think my LHS sells less than 10%.....
glowplugboy 12-21-2005 11:49 PM
ORIGINAL: muddrunner1968
Because it is a bushed engine, make sure you have castor oil in the fuel. Omega would be an excellent fuel as it has castor oil as the main lube with some sythetic oil. 5 to 15% nitro is AOK.
Regards,
GPB
Rcpilot 12-22-2005 12:35 AM
Glow fuel usually works best;)
In all seriousness--just buy any commercially available fuel from the LHS. High nitro is just a waste of money unless your competing at high levels. For instance--racing--IMAC, etc...
Run your engine on 5% nitro and don't worry about the rest. Any commercially available fuel will have enough oil in it.
It's not complicated. Just keep it simple and you'll have the best luck.
SBR_RV 12-22-2005 01:54 AM
10-15%
MinnFlyer 12-22-2005 07:48 AM
10 - 15% is just not needed in a bushed 2-stroke.
5 - 10% is plenty
deputydog 12-22-2005 08:29 AM
You will be chasing the needle with 15%! 10% is good to run in 90% of the motors on the market, especially bushed motors.
FlyingPilgrim 12-22-2005 11:45 PM
10% in this engine. It does not have the high compression ratio and timing that would give benefit of using a higher nitro.
