GP Ultimate Biplane
Got one for Christmas (thank you sweetheart :-) Great building on their part, the finish is perfect. Now.. what engine to use.. the manaual says that the DA 50 is not recommend as it over powers it, ( I have a new one in the box.... bummer) I also have a new Saito 180, but I would really like to use smoke on this one so I am guess it should be 2 stroke to get any real smoke. So...they recommend a 160, but I think I would like a bit more than that and I was thinking that dealing with the glitch problems from ignition type engines is not fun either.. What would you guys recommend? Don't care how much it costs really. I just used a Brisson engine in my 1/4 scale GB (adrian page kit) but I have not run it yet. GP recommend the 43 (?) Fuji, and I have a 50 Fuji in my GP Chrisian Eagle (also never started that one yet, lol) but as I said, I was thinking that a large displacement 2 stroke glow engine would be nice.. low wieght, no ignition and it should make good smoke (or not?). If I do use the DA 50, could I not prop it right to get good vertical with less air speed.. maybe a 3 blader?
Any help is appreciated.. by the way anyone got this bird yet... any improvements required on the engineering end of things? Best regards, Randy |
RE: GP Ultimate Biplane
If you are wanting to stick with a large 2-stroke glow engine, and think the 1.60FX is less than what you want - try a Moki or Mark 2.10 - chiefaircraft.com or morrishobbies.com carry them. The Marks are the same basic engines, rebadged for US distribution from what I have heard.
To the Saito 1.80 you have - it would be a decent candidate - and I've seen smoke on one and it looked fine - you need to create a pre-hearter coil in the muffler before it dumps out to let the smoke oil heat up good. www.rcdon.com has a good how-to on this process - click on Aircraft Videos then on supersmokers part 1 and then 2. |
Here is a great thread on that very plane
http://www.rcuniverse.com/forum/m_32..._1/key_/tm.htm Use the DA50. They ahve been coming out way heavy. Mine is 16lbs with a Brison 3.2 and was the same weight with the Fuji 43 The 3.2 brison was a great match and really allows this plane to do what it can do |
| All times are GMT -8. The time now is 08:23 PM. |
