RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   phoenix models extra 300s wing glassing (https://www.rcuniverse.com/forum/arf-rtf-75/3829262-phoenix-models-extra-300s-wing-glassing.html)
sackingsfan 01-26-2006 08:09 PM
ok guys i have a question about wing glassing. i want to fiberglass the wings together for peace of mind. are there any how to guides for this online. or does anyone have any tips for this ??
thanks in advance.
RCShadow 01-26-2006 08:53 PM
RE: phoenix models extra 300s wing glassing
I have built a total of 47 kits and/or ARF's to date from .30 to 2.4ci and use this method...
1) Get some fiberglass cloth. Wing center section glass can be bought (about 4"-6" wide) but regular glass works too (7.5oz or heavier).
2) Remove the covering from the center of the wing being careful not to cut into the wood.
3) Join your wing halves as normal per your instructions.
4) Roll the fiberglass on a small dowl (or similiar) as it makes it easier to handle.
5) You can either use epoxy or CA (personal choice).
6) Start by tacking down the end of the fiberglass at your starting point.
7) Soak the cloth enough to get it stuck down well and if using epoxy use a credit card (or similiar) to remove the excess. If you are using CA, just work the CA into the cloth with a finger covered with a plastic bag. WARNING ! The fumes from the CA when done this way are powerful ! Watch out for your eyes ! I have come away looking like a had been crying for 30 minutes while doing this so be careful with CA !!
8) As you go, unroll the fiberglass on the dowl and work your way around the wing.
9) Trim the excess and stand back and admire your work ! Now get the CA off your finger where the plastic bag got a hole in it :) .
10) Recover the center section with matching covering material. I do some prep and fill the glass with some Model Magic Filler (I have used spakling for this too but its heavy) before covering to make it look seamless. I just apply the filler, let it dry, then knock off the excess and sand smooth. It may take two coats of filler to get a good smooth surface.
That is what I do and I have never had a wing fail on me. I am sure others have other ways that will work. I built kits in the early 80's (mostly Goldberg) and this is how the instructions say to do it for most of their kits. If you have any questions or I was not clear on something, just ask !
CJ
sackingsfan 01-26-2006 09:36 PM
thanks for the detailed info. One other question. am i applying the epoxy to the wing and then laying the cloth on it or am i laying the cloth down on the wing and then applying the epoxy to the cloth.
thanks in advance
RCShadow 01-26-2006 09:44 PM
If using epoxy, I put some down first just so the glass will have something to stick to. Then epoxy the cloth down by soaking the cloth with epoxy and using a credit card or your finger (in a plastic bag) to "press" it through the weave and onto the surface of the wing.
Remove as much of the epoxy as you can without disturbing the weave in the glass and you will be good to go. If you dont remove the epoxy while its wet, you will have to when its dry and I know I don't have to tell you how hard sanding epoxy is [X(] .
Does this have a wing tube ? Nothing changes, just curious. I wonder if you will need to epoxy the tube in place if it has one ?
Just a thought :eek:
CJ
sackingsfan 01-26-2006 10:26 PM
no wing tube just a thick wood joiner. That is why i wanted to glass the wing
RCShadow 01-27-2006 07:51 AM
Great ! Let us know how it comes out:D .
CJ
