Hanger 9 Alpha Trainer
I was wondering if any one has flown the Alpha trainer. I got one and was told by my instructor that the left wing is warped slightly. The only way the plane will trim out on the main transmitter is if the left aileron is down about 1/4 inch. The main transmitter trims out but the buddy box aileron trim is all the way to the right, and the plane still banks to the left slightly. I have flown the plane 5 times and the instructor is not able to get it any better. I am shipping the wing back in hopes of getting a replacement. I was just wondering if anyone else has encountered this or had a different fix.
Thanks for the info. |
Hey Motor,
It is very easy to put a warp in a wing by simply shinking the covering too much. You could put the wing on a flat surface and careful force the wing to sit flat WHILE heating the covering back up. You will have to do the same thing on the underside of the wing once you have done the top. What I do here is use a heat gun and try to maintain some heat all along the wing panel and once you have reached the point where you can stretch or shrink it, lay the bottom of the wing panel back on the flat surface and hold it there for a minute or so. While holding the wing down when you finished step two, reheat the top and continue to hold it there. If the warp was caused by the covering shrinkage, this should fix your problem. |
Thanks for the info, I boxed the wing up and am sending it back tomorrow. It is a great flying trainer.
| All times are GMT -8. The time now is 11:13 AM. |
