RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Aresti help (https://www.rcuniverse.com/forum/arf-rtf-75/41788-aresti-help.html)
Cuda 01-27-2002 01:25 PM
Aresti help
Any help on the H9 Aresti would be appreciated. I'm putting in the Saito 72 and wondered about what type of fueling system others have used, In the past with some other Saitos ,I have had problems with remote fuelers slowing flow, and lean runs if the remote fueler is lower than the carb.I,ve used Robarts fueler also but not happy with it either. How about fuel dots. Any help..
Cuda
chris100 01-27-2002 11:51 PM
Aresti help
I just put a third line in the tank and let it hang out the bottom of the cowl. Works great.
shmo46 01-28-2002 10:36 AM
Aresti help
Hi,
Fuel dots are trouble free, you don't get the advantages of a quick connect nozzle, but they don't have valves to leak and you can plumb them straight into the tank so they aren't even in the fuel supply line.
Dubro filter clunks (officialy called RC tank filters cataloge #161) are also a great addition to your fuel system, they remove air bubbles, provide filtering. they are just a bit lighter than a traditional clunk, so you may need to use light wall tubing to help it reach the places it needs to go, but i think youwill like the results
Good luck! Love that Aresti!
Shmo
