Airplane
Hi i am looking to buy an aircraft and i wanted some suggestions here is what i am looking for
Almost redy to fly Eletric brushed 15+ minuts of fly time Good for beginer stable and easy to control slow fly can land and take off from grass for flying in park Can handle littel wind 0-300 dollars Thanks for any input or suggestions |
RE: Airplane
Have been looking some and have not found any. Still need suggestions
RE: Airplane
Random thoughts:
A plane small enough to be a park flyer usually can't take off from grass. To get the 15 minutes of air time you probably need LiPo batteries. The Clancy Aviation Lazy-E-Bee sounds about right but I don't know if it will take off from grass (I don't even know if it has wheels) and I don't know how it will handle a breeze. The small Sig electric Rascal won't take off from the grass and may be a little harder to fly. I'm having trouble reconciling the big plane properties (take off from grass, handle a little wind) with being able to fly in a park. What have you seen that comes close to what you want? |
RE: Airplane
OK, it is not a park it is more of a HUGE field. now i am looking for about 7 min fly time i will lookin to the ones u said
RE: Airplane
I like the balsa look the best Me No Like Foam
RE: Airplane
http://www.hobby-lobby.com/soareasy.htm
Beginner is a broad description. I wouldn't say this is for a first timer. But if you've flown before, I think this would make a good "trainer" type airplane. I wanted one for a while but bought too many other planes before I saw it. I think it would be a great 2nd or 3rd plane. |
RE: Airplane
Well i am a beginer i have bought about 5 planes but they were all like 30 dollar planes and did not fly, so i need one that will be easy to learn and fly
RE: Airplane
http://www.hobby-lobby.com/miss2.htm
Something like this is more what you are looking for. It is big and floaty, and is only three channels (no ailerons). And it has a very forgiving wing design. Check out Towerhobbies.com for similar 3 channel planes. This is the plane I learned on. I had zero experience and really only crashed it the first time I flew it. I wouldn't consider this the best choice for a first plane, but it's a RTF, so you can skip the hassle of the build. And I wanted a "scale" plane, so this was it for me. Red Rocket usually gives you a second battery for free. http://www.redrockethobbies.com/Park...100pkz1021.htm |
RE: Airplane
alienx - I haven't seen that one before either. Looks good!
andrewtexas123 - I saw a T-shirt once that said "Friends don't let friends fly foam!" But, if you have never flown before and don't have an instructor but do have a big field then you might want to try somthing like the Easy Star just to get started. http://www.nesail.com/detail.php?productID=2730 |
RE: Airplane
I definitly do not want foam
RE: Airplane
I like the look of like a cessna with the above wing. any links to something like this
RE: Airplane
Need more links have not made up my mine.
RE: Airplane
Ok i kinda want a mini that is relly stable and is eay to fly brusshless or brushed thanks
RE: Airplane
RE: Airplane
i need some thing like this wacth the video
http://www.slowfly.com/store/view.ch...view=%23497104 the only prob is it needs to be rtr i have changed pric range to max 200. needs yto be balsa |
RE: Airplane
have a look at Puffin models website. Since you are in the UK buy a good monthly mag and check the ads. Try RCM&E, RC Model World,Quiet & Electric Flight, etc., You can get them in any good newsagent and with $200 there is plenty of choice.
RE: Airplane
I am ordering from us
RE: Airplane
RE: Airplane
You better read the description closer. It says, "For Experienced Pilots Only !" Your original post said you wanted it to be good for the beginner.
| All times are GMT -8. The time now is 04:09 AM. |
