Sig Somethin Extra help.
This is my first arf but second plane just to let you know. But my question is do I need some sort of extenstion for the alieron servos. thanks.
-Jordan |
Yup, I think a 6" extentoin would work. Make sure you "fix" the aileron lead to the extention with tape or something that will not let is separate.
I have some standard JR servos in mine. The leads hang out of the wings by 3/4". I still use short extentions just so I don't have to hunt for the correct rx ports.
I am running hitec 605's and I have just enough length that all I have to do is plug the servos into a "Y" when I put the wings on. So if you are carefull, you don't have to have an extention. I haven't used one on mine yet, and I have 3 SE's..........
Originally posted by CHassan Make sure you "fix" the aileron lead to the extention with tape or something that will not let is separate. |
| All times are GMT -8. The time now is 10:35 AM. |
