RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   73 " H-9 CAP Question (https://www.rcuniverse.com/forum/arf-rtf-75/481213-73-h-9-cap-question.html)
M3 01-14-2003 01:31 PM
Does the H-9 73" CAP have a solid sheeted fuse bottom? My H-9 Edge does not, but my GP Wagstaff does. I have a H-9 CAP on the way and really need to how the fuse bottom is constructed (I am planning on adding a set of 1/4 scale floats to the CAP . . .).
Thanks!
splais 01-14-2003 01:58 PM
Aft of the wing it is not solid.
stomper 01-14-2003 01:59 PM
1 Attachment(s)
Hey Mpowrmnt
The H9 25% Cap has a lite plywood bottom with three large holes for lighting. Hope this helps.
Doug
M3 01-14-2003 02:20 PM
Good to hear. Now, I if I can gain access to the fuse bottom aft of the wing, I should be able to add a plywood landing gear mount for the second set of landing gear I will need for the floats.
I have wanted to put a 1/4 scale plane on floats, so I chose the CAP as it is something other than the typical floating CUB (or Cub-like plane), and it is so good looking.
I'll post some pictures when it's done!
