RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   TWIST 60 3D (https://www.rcuniverse.com/forum/arf-rtf-75/4869683-twist-60-3d.html)
glowfuel 10-15-2006 07:03 AM
TWIST 60 3D
Regarding the Hangar 9 Twist 3d 60:
Would this plane benefit from flaperons or should I just connect the ailerons with a Y-harness?
Am running an OS 91 FX, APC 14x4W prop and 15% nitro fuel. Should be a nice power to weight ratio for 3d.
Thanks in advance....
suitcase 10-15-2006 01:56 PM
RE: TWIST 60 3D
If you have enough channels on your TX I would use ch1 and ch 6. It just makes setting up so much easier for me.
Planeclothes 10-15-2006 04:36 PM
RE: TWIST 60 3D
Mine is set up with channels 1 and 6 for ailerons, even though I actually don't use the flaperon function. You don't need flaps with this big fat wing, but having the ailerons on separate channels makes it easier to set individual throws, centering, etc.
