RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   CMP Edge 540-T (https://www.rcuniverse.com/forum/arf-rtf-75/4886243-cmp-edge-540-t.html)
Sessholvlaru 10-18-2006 09:44 PM
CMP Edge 540-T
Hey all. I recently picked up a 70" CMP Edge 540-T from eBay. Seems to be pretty well built, but a bit on the heavy side. I glassed the wing mounts and firewall now to hopefully eliminate some problems later on. Not sure what engine I want for it....probably a YS1.10 or 140. Anyone have any luck with this plane? Here is a link to some site that sells it just for reference, although the cowl on mine is painted a bit different. I can't find anyone on RCU that has posted about one yet. Thanks.
http://www.nitroplanes.com/cmped54arf90.html
cosmospho 06-04-2007 08:27 AM
RE: CMP Edge 540-T
Hi look for the CMPRO and the Edge 540T 120..... They somehow placed it in a different category....
I also have one which is running with a 25cc gas engine, its shaking apart but I did no re-enforcements or checked the glue joints. Before its maiden I will CA the joints and epoxy the firewall to give it a little more strength.....
I will keep you posted on the maiden....
Cosmos
pnr 06-04-2007 12:05 PM
RE: CMP Edge 540-T
There are a few threads on this plane out there, they are just hard to find. I am finishing up mine now, I am going to use a 1.10 2 stroke. Looking forward to putting it in the air soon.
damroadhog 06-06-2007 01:07 PM
RE: CMP Edge 540-T
Hi
I have one , it's a year old now and doing fine with an EVO GT26cc on her, she is a fat ass at 12lbs.
But she jumps right up there , It really is a nice flying plane and would be alot more fun if you could keep here wgt down around 9 to 10 lbs
Re- glue anything you can reach, if you have the fiberglass landing gear toss it in the trash or use it on a smaller plane, it will fail !!!
If I were to do it again I would put an E-flite BL 110 on this and let her rip.
The plane is a good one .
Dave
