edge 540
i am finishing out the hanger 9 arf edge540... i am having problems with the mounting of the saito 180. the rocker arm covers extend past the right side of the fuselage. if anyone out there can help i would appreciate it. thanks to all
Rocker arms
Hey,
Its OK that the rocker covers are sticking out. You will need to cut slots in the cowl for the rockers to protrude thru. Use a dremel tool and this is easily done. Good luck. Andy |
| All times are GMT -8. The time now is 09:15 PM. |
