Phoenix Sukhoi - 31
Hey guys, I was looking at my hobbie store the Su - 31 from Phoenix Models. Does someone has this airplane? Is a good ARF model? It is a good 3rd plane?
Thanks guys saludos Jorge |
RE: Phoenix Sukhoi - 31
i had the phoenix suhkoi 31. if you get it i would suggest you put a .50 to .60 2-stroke on it. for 4-strokes i do not know. also i would not use the 2 piece nylon motor mount that comes with it or you will have engine vibration problems. i had enya .50 cx on mine and i had to mount the engine on the extreme end of the mount for proper cowl fit. i ended up using a 4-stroke mount on it. do not do medium to slow tight turns with it or she will snap out. other than that it's a nice plane.
| All times are GMT -8. The time now is 11:42 AM. |
