91FX in a ZEN 50
I have a zen 50 comeing and i see guys putting OS61 in them so i was wondering if a 91Fx would be to much.They both fit the same mount or will a YS 45 be just as good.
Thanks Glen. |
91FX in a ZEN 50
Absolutly, forget it.
It isn't a weight thing... it's about the power/trust/aerolane size ratio... You'll be needin' like 15 degrees of right thrust!!! Plus a bigger fuel tank, lager prop(ground clearence probs') etc etc. The YS is a better way to go... and hey, you can put the tank on the CG. Something you cant do with the FX without a cline. |
| All times are GMT -8. The time now is 04:46 AM. |
