RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   H-9 Edge and Brison 2.4??? (https://www.rcuniverse.com/forum/arf-rtf-75/52817-h-9-edge-brison-2-4-a.html)
Mike Rojas 02-12-2002 02:43 PM
I am getting ready to build a H-9 1/4 Cap232 with a Brison 2.4 for friend.We are considering an H-9 Edge instead.Is this a good idea or not?I already have had a H-9 Cap with a Brison 3.2,so I know it can handle the 2.4.I also have the Lanier Edge with a 2.4,and it seems to be OK so far.What do you think about the H-9 Edge and the 2.4
mikerc 02-12-2002 03:36 PM
Edge
1 Attachment(s)
I had a Fox 2.4 on mine and it worked great. The fox is the same engine as the Brison but the crank is polished. I put the fox on my H9 Cap. I am going with a ZDZ 40 for my new Edge.
I just spaced the engine out 3/4 of an inch and moved the cowl back to match. This helped with cg. I also put three servos in the tail.
mikerc 02-12-2002 03:37 PM
servos
1 Attachment(s)
This is a shot of the rudder servo on the bottom. I will set up with pull pull. Works great.
OUTCAST 02-12-2002 08:44 PM
I have a brison 2.4 in a Kangke texas hurricane and its a killer combo. The plane looks just like an edge and the brison gives unlimited verticle.
