EDGE 540
ANYONE GOT ANY IDEAS ON A NICE .40 SIZE EDGE 540 FOR 3D. I WANT A FULL FUSE NOT A PROFILE. I HAVE A .46FX TO THROW IN IT.
THANKS IN ADVANCE[8D] |
RE: EDGE 540
Pacific Aero Models ... Aero Works ... Fliton ... but with a 46 2C you cannot expect much for 3D, it might be hard to prop hang actually as most of the planes come up to about 5.75 - 6 lbs ... Best bet to 3D with a 46 2C is still to go with a profile.
RE: EDGE 540
ORIGINAL: tIANci Pacific Aero Models ... Aero Works ... Fliton ... but with a 46 2C you cannot expect much for 3D, it might be hard to prop hang actually as most of the planes come up to about 5.75 - 6 lbs ... Best bet to 3D with a 46 2C is still to go with a profile. I had the chance to do 3d on the Aerworks running a 50 in it and while it did OK, the control surface area's really left it lacking |
RE: EDGE 540
Edgeflyer
If you had a little larger power plant I would reccomend the Seagull Edge 540. I assembled one last summer and got to fly it a little before winter set in. really didn't get a chance to really wring it out as I had standard servos on it but have since replaced them with high torque servos. I have a Tower hobbies 75 on mine and it seems like it has plenty of power but like I said never go to really wring it out. clemrick |
RE: EDGE 540
RE: EDGE 540
I looking for 1 to put os 160
RE: EDGE 540
Look at these:
http://www2.towerhobbies.com/cgi-bin...?&I=LXMPN1&P=7 http://raidentech.com/newed549072a.html might be alittle small for a 1.60 |
RE: EDGE 540
I had a 1.60 os in this plane:
http://www2.towerhobbies.com/cgi-bin...&I=LXEUP9&P=ML It was a lot of fun and performed very well. I used an apc 17x6w and a zinger 18x6-3. bisson pitts style muffler. |
| All times are GMT -8. The time now is 04:13 PM. |
