hanger 9 super stick
I started this arf a few years ago, and got caught up in other projects. Plan to finish it. Any comments from super stick owners? Thinking of using a .914st either thundertiger or Magnum, .61 or .75 2st is a possibility....what have you used with this plane? Thanks!!
This is the one Hangar 9 ARF that I did not like.
It is really just a poor mans UltraStick. My problems with the Kit.. Shelfpaper covering. Poorly matched wing halves. Impossible to balance. I trashed it and got an Ultra stick 40. Much happier with this plane. |
good looking plane
1 Attachment(s)
This was my first Stick a couple years ago. Awsome looking but when I started flying it I realized I was having trouble telling weather it was inverted or not. It also flew heavy. I called it my lead sled. I recovered it in monocoat and it was my daily flyer. I lost it when I put floats on it. not sure what happened... stright up then stright down :( had no control at all BUT it responded like it was way tail heavy. I had an O.S. 61fx and many hours of enjoyment. Go with the biger engines... IMHO I'd go with the Tower hobbies 75... Had one on a 4*60 and never used a starter on it. Great engine for the money.
Jim |
I got a Super Stick 60 as a second plane after I learned to fly with a LT40. Mine has an OS70 4s and flys great. I usually fly at less than half throttle. It won't hover, but I can't go vertical and hang it for a few seconds.
I fly it with a JR radio and programmed it with flaperons. When I deploy the flaps I can really make it crawl. I bought it from a club mate who had an OS91 4s on it. I remember watching him fly it. It could really move. I'm sure you'll like it. Hope that helps. |
H9 SS.60 CG
ggale,
Just a word of caution. The CG of 1/8" behind the main spar, as indicated in the assembly manual is incorrect. I have some pencil notes in my manual which indicate the CG at 3/4" behind the main spar, not 1/8". This may or may not be correct; it's been a long time since I assembled mine. :confused: I suggest that you contact Horizon Product Support to confirm the correct CG. Regards to all! |
I have a Super Stick 60 with an Irvine 72 which pulls it great. Easy to fly and land. Shelf paper covering the biggest negative. Other than that, I love it.
| All times are GMT -8. The time now is 11:49 PM. |
