RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   VMAR Texan (https://www.rcuniverse.com/forum/arf-rtf-75/539759-vmar-texan.html)
Omurru 02-07-2003 12:51 PM
VMAR Texan
Ok I know this isn't the best of models but I got it cheap so I ain't complaining plus I got ailevator and flaperon set-up so that should make for some fun.
Question is how far back is the centre of gravity on your one? The manual which I don't even think is for the texan :rolleyes: states 3-4" back but in my plane it is sitting about 4.5" back...and I can't really do anything to move it forward as it already weighs 6.5lb....
Cattle_Prod 02-08-2003 04:52 AM
VMAR Texan
Kyle.
Forget the instructions and work it out at, 25% to 33% of MAC.
Start at 25%, this will be a little nose heavy however, it will fly ok.
Once your happy the plane flies straight and true start moving your C of G back a little at a time. A great test is to fly a 45 Degree upline, roll inverted. What happens? If your plane continues on the up line with no input correction needed, it is more than likely "Tail Heavy". If, on the other hand your plane falls out very rapidly, it is more than likely "Nose Heavy". What we are looking for is a very gentle falling out... C of G about right.
Hope this helps some
