RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   G-26 (https://www.rcuniverse.com/forum/arf-rtf-75/5503625-g-26-a.html)
ffdq 03-03-2007 01:52 PM
G-26
Hi,can anyone tell me what rpm I should get wuth a g-26 with a 18-6 prop.I,m getting about 7700 rpms now.The engine is on a G.P.super stearman.
thanks Fred
pettit 03-05-2007 07:33 AM
RE: G-26
Depends on the brand of prop.
Plan on about 8000 with 18-6 APC wide blade and stock muffler.
More with aftermarket louder muffler.
jrf 03-05-2007 11:38 AM
RE: G-26
I'm getting 9000 with an APC 17x6 and performance in the air on a 14 pound airplane is very, very good.
Jim
ffdq 03-09-2007 07:50 AM
RE: G-26
Hi I,m using a 18/6 classic with aftermarket muff.still only 7700 rpm,s.I have about 3 gals through it.I have been told it will get better with 5 gals through it what do you guys think? I have a 17/6apc maybe I should try that,the plane is about 14.5 lbs.
thanks Fred
jrf 03-09-2007 11:40 AM
RE: G-26
Try it, you'll like it.
Jim
waynem 03-09-2007 12:22 PM
RE: G-26
Hi FFDQ, I am running a 18x6 wide APC prop on a G26 on a older hanger nine stick and I turn it a little over 8200 RPMs. I run a 17x6 standard APC on a G23 mounted on a Jerrys big boy and it turns about 8600RPMs. Have you peaked the G26 engine? I am running a B&B muffler on the 26 and the stock muffler on the 23.Hope this helps you know to expect from you engine. Wayne M.
ffdq 03-09-2007 06:14 PM
RE: G-26
hi Waynem, Do you think there is much diff.in a apc or a classic prop,also what do you mean have I peaked the g-26.I,m using a b&b type muff.
thanks Fred
waynem 03-09-2007 06:38 PM
RE: G-26
Hi Fred, What I mean by peaking is leaning the high speed needle, the one on the outside. I lean mine to peak RPMs and then back off about 200 RPMs. I do this after seting the low needle for good transition from idle to wide open.I dont try to get every RPM from my G26, but I want it almost at max. I have only ran APC props on mine so far. On my G62 I changed from a Zinger 22x8 standard prop to a Menz 22x8 and saw a big differance in performance. Not so much in RPMs but pulling power, so there is a big diff. in props. You have the B&B muffler and I would try the 18x6 wide prop. or the 17x6 would be good also. You will turn it more,but on a bi-plane I would think you want pulling power instead of speed. Hope this helps Wayne M.
ffdq 03-09-2007 08:26 PM
RE: G-26
hey Wayne, I have a 17/8 apc prop and will try that and I will get a 18/6 wide apc and see witch one does better.I have not peaked the high end but did richen the idle.
thanks Fred
