RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Second plane (https://www.rcuniverse.com/forum/arf-rtf-75/5774530-second-plane.html)
Gstan 04-26-2007 04:02 PM
Second plane
I’m trying to narrow down my search for a second plane. Either the Hanger 9 Pulse XT, there Ultra Stick or a Great Planes Super Sportster. Any comments?
rolliedog12 04-26-2007 04:29 PM
RE: Second plane
I like the ultra stick, it was fun playing with the flaps using crow. It was a blast.
One vote for the ultra stick.
mtwister 04-26-2007 05:19 PM
RE: Second plane
Great planes has a plane called the Easy Sport, it's a little goofy looking, but it flies great!
L48 04-26-2007 05:20 PM
RE: Second plane
The Ultra Stick is a great flyer. It is easy enough to be a trainer and then you can really ring it out to do almost anything.
aussiesteve 04-26-2007 05:26 PM
RE: Second plane
Make that 3 votes for the Ultra Stick. they are a great fun plane to fly and are pretty capable of a bunch of maneuvers. I know of a couple of high level pattern fliers that use them to practice their patterns.
150flyer 04-26-2007 05:30 PM
RE: Second plane
1 Attachment(s)
Ultra Sticks are great. They can do just about everything and are tough.
waross 04-26-2007 06:24 PM
RE: Second plane
Hanger 9 Pulse Xt - bought one last year great plane and stable even at low speed. Great flight characteristics. Better build than the Super Sportster. I am very satisfied with mine.
Gstan 04-26-2007 06:38 PM
RE: Second plane
Regarding the Ultra Stick. How long of a build time? What size engine? Where should I purchase it from?
L48 04-26-2007 07:14 PM
RE: Second plane
There are three sizes. I like them so much I bought all three.
A 40 size I have a Super Tigre 51 on it.
A 60 size I used two different engines on it. First a OS 91 4/stroke and a Super Tigre 75.
A 120 size I have a Zenoah G-23 gas engine on it.
They all are ARF, not much building.
They are made by Hangar 9 sold through Horrizon.
aussiesteve 04-26-2007 07:28 PM
RE: Second plane
I have
A 40 size (Not an actual Ultra Stick - but a similar plane from a different manufacturer) with a Saito 72 on it.
A 60 size with a Saito 1.00
A 1.20 lite with a Saito 1.80
they are all great fliers and being ARF's took less than a week to build. IMHO the bigger they are the easier they are to fly but that is probably a vision thing. The bigger ones also cost more so you may be a little afraid to break them.
Look at your LHS they may have them (or similar ones) in stock at a good price. Otherwise Direct from Horizon.
GPutt33 04-26-2007 09:24 PM
RE: Second plane
I have to agree with the guys on the H9 Ultra Stik!! :D:) Easy ARF to put together. Go with the flaps if you have a radio you can program a little, it gives the plane a whole nother flying dimension I think. It will take a total of 4 servos just for the wings however. You can fly with just the ailerons, or tie the flaps to move in unison with the ailerons. Hi and Lo rates either way. Has a great roll rate [8D] Then you can either use the flaps as flaps to just float in or go with Crow - Flaps go up Ailerons go down, but yet all still respond to the stick. You can make the plane all most come to a stop in a dive.
My little 40 size I just fly with an OS55AX - not a power house, but fine for my style of flying.
The H9 US Lite 120 has an OS160 on it, and I think it's going to be as much fun or more to fly then the 40 size. I'm still messing with getting the engine broke in.
Ferocious Frankie 04-26-2007 10:16 PM
RE: Second plane
I recommend the Goldberg Tiger 60. It is a beautiful plane (check out my gallery) and it flies just as well. Set up with a 91 four stoke and a 13x8 prop it will really fly!
I believe it is one of the most recommended second planes on RCU[X(]
You won't be sorry!
stinger40 04-27-2007 01:42 PM
RE: Second plane
My Stinger 40 flies fantastic! Consider one of those. :D;)
AKFireMedic 04-28-2007 04:32 AM
RE: Second plane
I would vote Pulse XT. Great flying plane and the prettiest of the bunch that you mentioned. It is a bit fragile though so don't be rough with it.
150flyer 04-28-2007 07:31 AM
RE: Second plane
If you go with a 40 sized Ultra Stick, it's hard to beat an OS .55 AX with an 11 x 6 APC prop. Hovers at half throttle with power to pull right out. A good four stroke is the Saito .82 with a 13 x 6 prop. Has about the same power as the .55 AX but is twice the price.
I purchased a Pulse XT several months ago, new in the box. Before I got to build it, I trained a student to fly on the buddy box with his Pulse XT. It was extremely stable and fine for loops and rolls, but does not compare to the Ultra Stick in hovering, inverted flight, and flat spins. I sold the Pulse XT shortly after that still new in the box and still fly my Ultra Stick weekly, as I have for the past two years.
BlackB12 04-28-2007 08:09 AM
RE: Second plane
1 Attachment(s)
I don't think you can beat a world models skyraider mach 2 as the ultimate 2nd plane. Doea it all and it's only 70 bucks. I've been flying for years yet it still provides enjoyment for me. Knife edge circles are fun with it. I have a super tigre 51 on mine and it's ballistic. Flew fine with the Supertigre 40 I previously had on there. Here's mine.
straitnate14 04-28-2007 10:27 PM
RE: Second plane
what about the good old four star or a tower hobbies kaos?(not the best covering but great plane) these were some of my favorite planes before i got this thing for extra 300's i got 4 in my room and only ones ready to go...
Gstan 04-29-2007 08:12 AM
RE: Second plane
ORIGINAL: BlackB12
Looks good. This would be a great plane for me and something for my kid to fly after he learns on his trainer. How much of it is pre built? How long to put it together? I could not find too many reviews on it.
AKFireMedic 04-29-2007 02:02 PM
RE: Second plane
True enough, the Pulse isn't much of a 3D machine but that isn't what it was designed for. It is however, a great 2nd plane.:D
BlackB12 04-29-2007 06:30 PM
RE: Second plane
ORIGINAL: Gstan
ORIGINAL: BlackB12
It's definitely the most complete and quickest assembling ARF I've "built". All flying surfaces are already hinged and glued in place. THe tail feathers interlock then bolt together so no glue needed back there. I was nervous about a bolt in tail but mine hasn't even come loose in about 150 flights. Basically just glue the wing halves together (5 min epoxy) and mount the engine, then hook up the hardware. Hardware is decent and went on in reocrd time thanks to having the pilot holes PRE-drilled! No alignment needed. Mine might have taken 4 hours to complete tops and that was me just double and triple checking things. Next one most likely can be built in under 3. I'm very impressed with the quality of this ARF for an absurdely low price.
If you search this forum there's tons of reviews.
Mike
