RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Somethin Extra engine mount bolts (https://www.rcuniverse.com/forum/arf-rtf-75/5780282-somethin-extra-engine-mount-bolts.html)
Dusty14 04-27-2007 07:09 PM
Does anyone know what size of bolts are used for the engine mount of the SIG Somthin" Extra. It appear that I have lost them in the middle of a flight, don't know how it happened without me realizing till I landed, but anyways, it appears that they might be metric as I can not find a bolt that will fit the blind nuts. Oh and I lost my manual so I can not chek for myself. Any help is greatly appreciated as I can not fly before I get these bolts[&o]
fossil 04-28-2007 01:09 PM
RE: Somethin Extra engine mount bolts
are you talking about the ARF or the kit ? and I assume you mean the bolts that hold the mount to the firewall not the bolts that hold the motor to the mount. I have the ARF I will look and see what mine are.
fossil
Dusty14 04-28-2007 01:44 PM
Yes, I do mean the ARF. And yes it is the the bolts that hold the mount to the fire wall, they all came unscrewed when I was flying last sunday.
Salty25 04-28-2007 06:37 PM
I don't remember what size bolts went into the SSE I had. I lost the plane when I had dumb thumbs years ago.
If I may suggest: Swap out the blind nuts and putting in SAE bolts? I try to swap out the metrics when ever I can, just makes it easier to get replacement bolts and nuts.
Dusty14 04-28-2007 09:42 PM
If I were doing it again I might, but it makes it a little more difficult when everything is alread in. I never really thought of this while I was building, but thinking back, loctite would have been a really good idea. Just about lost the plane do to the engine coming off. Betcha havn't seen that before.
fossil 04-28-2007 10:16 PM
Sorry I got side tracked, I have the book in front of me now and it says: (PM4 x 22mm Phillips head bolts - motor mount) I don't have a clue what a PM4 bolt is unless it is just a 4mm bolt, the 22mm is the length of the bolt I'm pretty sure. Hope that is what you are looking for.
fossil
Dusty14 04-29-2007 08:46 AM
Fossil, that is what I am looking for. I think that that is a 4mm bolt. Now comes the next problem, where to find them. Thanks for all the help.
fossil 04-29-2007 10:00 AM
Your welcome, Do you have ACE Hardware stores there? If you do they will have them.
fossil
