Beefing up a H9 1/4
I saw a post on RCO that some one was wrapping the front end of the cap with fiberglass and renforcing the firewall. If i'm putting an RCS 1.8 and only doing mild aerobatics do you think it is necessary?
Thanks Pat |
Beefing up a H9 1/4
Wraping the fire wall in glass isn't nessesary but I'd reccomend it. I've powered 3 of these with a ST 2300, Moki 1.8 and a Moki 2.1. Each one had the fuse side split in line with the firewall and one example split the corner blocks. Yours should be fine doing normal acro (I do a lot of 3D) but if you nose it over on landing you will crack the firewall loose.
I cut the triangle stock forward of the firewall off, It's useless because the fuse sides are prone to shearing behind it! I then rounded the corners of the firewall and laid glass across it and 6" back in the sides. The cowl covers most of the ugliness so you don't even have to recover! You could always replace the entire nose with 5-ply aircraft and carbon. That's what it tool to keep the Moki 2.1 attatched :D |
Beefing up a H9 1/4
I wrapped the firewall on my cap with fiberglass too. I highly recomend it. Just about everyone I know with one of these planes has had the firewall come loose. I use Z-poxy thinned just a little with alcohol and it works really well. I have started doing this to all my planes. It really makes the nose fuel proof! Hope this helps.
Beefing up a H9 1/4
OOPS.
| All times are GMT -8. The time now is 09:54 PM. |
