RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Glow Driver Help...? (https://www.rcuniverse.com/forum/arf-rtf-75/5911192-glow-driver-help.html)
warhawk00 05-28-2007 07:16 AM
I need some help. I have had a RAM glow driver on my saito 56 since it was new. I could never get a reliable idle. I may try to do without now that it is broken in. I noticed short battery life on my glow driver and after troubleshooting, i realized it was not shutting off. I called ram and they insisted it was my hook-up. It was in for 3 years and nothing changed. So, since the battery was on back-order, i bought a new driver. Guess what, same thing. After playing around, it started working. Ready to fly after a long down time repair, i charged all batteries and i was off. When i got to the field, IT WAS STUCK ON AGAIN!!! Any suggestions...? Please Help... [&o]
tail strike 05-28-2007 08:15 AM
RE: Glow Driver Help...?
Your glow driver plugs into the reciever, you setup the channel that the driver is pluged into to come on at low throttle or you can set it up to come on at the flip of a switch. You can adjust when it comes on with the ATV on that channel.
Larry S
ORIGINAL: warhawk00
bjb6723 05-29-2007 03:46 PM
If you have the RAM glow driver hooked to a Futaba reciever, you need a special "harness" to go in between the two. I had the SAME problem. Call RAM and tell them your setup and they will ship you a harness for like 5 bucks.
