Pulse XT40 PNP Setup Need Help!
Ok I know some of you might go...why the heck is this guy asking for help with an airplane that is pretty much an RTF. What my problem is, in the instruction booklet the instructions call for you to wrap the receiver in foam then plug in all your servos, battery, extensions etc...What I don't understand is how to plug them all in if pretty much the whole receiver is wrapped up already. Also there is slot for the battery which fits perfect wrapped in the supplied foam, the other small slot is for the receiver which I don't have a clue how to sqeeze it while its all wrapped up in foam in with everything hooked into it. I had everything hooked up earlier, but something just did not seem right the way it sat...should the receiver be laying flat or tipped on it's side when it is sitting in the plane?
Help and input much needed Thanks |
RE: Pulse XT40 PNP Setup Need Help!
Plug the servos and switch harness into the receiver first, then wrap with foam. As long as the receiver is snug and can't shift around, and protected from vibration with none of the extensions tugging with tension it'll be ok.
| All times are GMT -8. The time now is 05:05 PM. |
