RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Control throws for four star 40 (https://www.rcuniverse.com/forum/arf-rtf-75/6024494-control-throws-four-star-40-a.html)
what_stanger 06-23-2007 02:23 PM
I am posting here just to get a few more replies, maybe someone will know the actual throws. The plane in question is a kit, but they're also available ARF, so I figured this fits. Besides it will dwindle out of the first page after a day i'm sure anyway.
original post is here:
http://www.rcuniverse.com/forum/m_6024491/tm.htm
thanks for looking.
carrellh 06-23-2007 02:40 PM
RE: Control throws for four star 40
If you don't get what you need before Monday; get the phone number from www.sigmfg.com and they'll give you all of the info.
what_stanger 06-23-2007 02:43 PM
Thanks.
I called up tower hobbies today to ask their tech, but they weren't in. Tower gave me the number for SIG. I was just hoping to see what everyone else did. I flew the plane already, and then checked the throws and my ailerons weren't throwing as much as it calls for (or were they?, tower has a weird glitch in that info).
I'm curious what someone may have used as a high rate as well.
ChuckW 06-23-2007 02:51 PM
I didn't see my 4* manual sitting on the shelf. I'll dig around for it this afternoon and post the throws if I find it.
N1EDM 06-23-2007 08:44 PM
If you can't find that manual, I'll dig mine out.
Bob
ChuckW 06-23-2007 10:32 PM
I must have accidentally tossed it; I can't find it anywhere.
what_stanger 06-24-2007 12:58 AM
Its cool man, I appreciate you looking.
Does more aileron than elevator sound right?
CustomPC 06-24-2007 05:04 AM
From the ARF Manual
Elevators: 1/2" Up -- 1/2" Down
Ailerons: 5/8" Up -- 5/8" Down
Rudder: 1" Left -- 1" Right
Recommended CofG Balance Point is 2-15/16" which is right in the centre of the main spar.
what_stanger 06-24-2007 10:59 AM
thanks.
Mind I ask you what you use on high rates, if you use anything?
CustomPC 06-24-2007 05:02 PM
I'm still using the throws as per the manual.
The aileron and elevator are fine at those settings. The rudder could use some more for better knife edge.
what_stanger 06-24-2007 06:42 PM
I took it up again today with the above throws. It was pretty good.
When I kick the rudder for a knife edge, the nose pitches down wickedly. I'm no good at mixing, so I don't know what I'll do there.
thanks again.
CustomPC 06-24-2007 06:55 PM
ORIGINAL: what_stanger
That's a typical Four Star trait and it comes from the horizontal stab being too high. Mine does exactly the same thing.
