RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Gp Giles 202 1/4 Scale, Upthrust Problem!!!! (https://www.rcuniverse.com/forum/arf-rtf-75/61221-gp-giles-202-1-4-scale-upthrust-problem.html)
amcross 04-22-2002 02:23 PM
Obsessed,
As indicated in my post above, the model SHOULD NOT have "a ton of upthrust". It should be at +1 when referenced to the wing, which results in no need to 'drag the tail'.
crash0001 04-23-2002 02:00 AM
Have any of you noticed a lack of elevator on landing? I "run out of elevator" when flairing unless I have a little power on...
Chris
P.S. I have set my control throws at the factory settings and am on high rates... My C.G. is on the forward side of the suggested range..
Ron Irving 04-23-2002 08:39 AM
AnneMarie,
Thank you for taking the time to help
us out. I have a G202 that I had just started putting together when I read the earlier posts.
I decided to wait for some more feedback before
proceeding to fix the stab in place.
The build quality ans covering are way better than
I could ever do, congrats on a first class product. It was a little expensive down here in
(Australia)but so far I am very impressed.
amcross 04-23-2002 11:21 AM
Chris,
Your tail is getting "washed" by your engine incidence, i would almost guarantee it. You should have tons of elevator on landing.
Folks -- they should DEFINITELY be +1 stab and engine to a 0 wing, and all kits currently in stock meet that specification. apparently some models shipped must not have. If anyone has an unbuilt fuse that is drastically off, if you would be willing to return it to me for exchange so we can figure out what went wrong, i would GREATLY appreciate it. Please contact me by private message or email to do so.
RickP 04-23-2002 03:02 PM
Anne,
I will double check mine again tonight, but I'm sure it's 0-0 wing-stab. The stab did also have a little bit of play but I had shimmed it so the stab was as positive as it would go.
Rick
crash0001 04-24-2002 02:41 AM
Anne,
Could you explain more about what is happening with the elevator "wash"..
I have flown with the factory setting for upthrust and have also put some downthrust and the problem with lack of elevator on landing has not changed..
My CG is at the forward most reccommended spot.. Do you think this could be the cause for lack of elevator response?
Chris
louden 04-24-2002 03:03 AM
Is the right side engine thrust correct?
Mine seems to have an awful lot of right thrust. What should the correct side thrust be?
Louden Kleer :confused:
amcross 04-24-2002 10:52 AM
Crash,
If the relation of the wing to the stab is way off, teh wing will "wash out" the stab so that the stab doesn't get clean air at low speeds, therefore giving you no response.
Yes if you are on the forward most CG and on low rates you will likely be running out of elevator. try a little more throw or nudging your CG back a hair.
The right thrust is 2-3 degrees.
RickP 04-24-2002 11:39 AM
1 Attachment(s)
Hello AnnMarie,
I'm not sure how you would check an unbuilt fues but I might be willing to send mine back. The Stabilizer is mounted and I checked last night and with the wing at 0 degrees this fues actually has -1/2 degree of incidence in the tail. I took some pictures, but my camera is not all that great. You can't see it well enough in the pics but you can see my set up and the wing reads zero and the stab -1/2.
RickP 04-24-2002 11:40 AM
Wing Incidence
1 Attachment(s)
This pic shows the wing
amcross 04-24-2002 12:03 PM
Rick,
It'd be very easy for us to check your fuse. Yes, please send it back to me. Email me privately and we'll send you a call tag to get it back and pre-ship you another fuse "open account" (when yours gets here we clear the invoice).
RickP 04-24-2002 12:07 PM
Tail incidence
1 Attachment(s)
This is the tail shot
RickP 04-24-2002 12:11 PM
Stab Mounting
1 Attachment(s)
Here is a close up of the stab mounting. You can see that I propped the LE of the stab up close (No gap) and let the TE drop down.
And you know I just realized that the -1/2 on my incidence meter is actually LE up on the Left side of the airplane. So I actually have +1/2 incidence. Sorry about that.
If I didn't prop up the front I probably would have 0 incidence.
Rick
amcross 04-24-2002 12:13 PM
Rick, that's good to hear -- +1/2 on the stab is fine when compared to a 0 wing; however, my real concern is the angle of your firewall. as you indicated previously that it was very obviously mroe than 1 degree up that's what we really want to see and try to figure out why.
RickP 04-24-2002 12:35 PM
Thrust
Hello AnnMarie,
I think that was Paul's ARF that had the up thrust problem. Mine was OK.
Rick
amcross 04-24-2002 12:36 PM
Rick, my confusion. Don't need your fuse then, no.
Ron Irving 05-05-2002 02:35 AM
Annemarie and others,
FYI
I have the following information regarding my
GP G202 kit
From the factory the incidence angles were:-
Stabiliser 0 deg
Wing +1 deg
Firewall + 2 deg
As per the info in this thread for AM.
I have reset the Stab to + 1 deg
Now working on the wing to bring it back to 0 deg
Will use spacers to bring the engine mount back
to +1 deg.
Looks like it is a common problem.
Ron Irving 05-06-2002 06:22 AM
AnneMarie and others,
Further to my last post
The right thrust at my firewall is 3 deg
Upthrust is 2 deg
Stab was 0 deg now +1 deg
Wing was +1deg now 0 deg
Regards
Ron
Ron Irving 05-06-2002 08:24 AM
Just rechecked the thrust angles 3 times.
Right It is actually 2 deg not 3deg
So it is correct.
Up is still + 2 deg
Cheers
Ron
Shortman 06-28-2002 10:34 PM
What engines are you guys running in your giles 202?
Shortman 06-28-2002 10:35 PM
The more i read this thread the less I want the plane
Geistware 06-29-2002 11:09 AM
I can say this, One month ago I had my hardest landing with a plane without it being totaled. Our field marked the runway with stakes so that it could be paved. I didn't see the stakes, I hit it on landing which flipped my plane over and spiked the rudder destroying the top half. The left landing gear was still straight, the right was bent 33% (yep, I measeured it.) Their was a small 2-3 inch crack but no breaks and no other damage. the plane is now back together and I will fly it over the holidays.
You CANNOT ask more of a plane or its builder than that. The plane is sturdy, flies great, and if this is an indication of Great Plane's ARF quality then I am sold. I have measure the thrust of both of my planes and they are both around 1 degree. I just use two yard sticks and measure the difference and use trig to solve the angle.
Shortman 06-29-2002 04:10 PM
Well what I would like to know is if they are going to fix the problem? Then I would happily buy one
mancha 07-16-2002 03:42 AM
it is July 2002, any news from GP regarding the giles 202 ARF??
I am going to fly it for the first time next saturday!!
I was adviced by La PAZ Baja club to give down trim on the elevator as well !!
please reply. Thanks
amcross 07-16-2002 11:17 AM
Mancha,
With all models we've had here, and the 2 that have been sent to us, we've found no problem. I am still waiting tos ee a problem aircraft so we can try to get to the bototm of what may have been wrong with a tooling or something ot be sure we avoid it in the future. All kits in stock, and all the kits our R&D and design teams are flying, are set exactly as called for and fly perfectly. additionally i have talked to not less than 100 VERY happy owners of this aircraft who have no problems at all.
please, all BE SURE you are using the CG as listed in the manual and the SECOND addendum. the first addendum was printed in error. CG is from the TRAILING edge of the wing not the LE. if from the LE you'll have a tail heavy handful....
