Where to find CMP ARF Models
I am looking for the CMP Pro .40 size Cessna with the Fiberglass fuse. Anybody know where to find this model?
I want a 40 size Cessna and this one seems to have the most features for the $$. nitroplanes.com are out of stock |
RE: Where to find CMP ARF Models
Try Ak-Models. They might have it in stock.
Pat Forget it. I just looked and it's the Richmodels version. |
Right here: http://www.nitroplanes.com/arfce182arfs.html
http://site.nitroplanes.com/cessnaarf.jpg BEAUTIFUL plane. Caveats Watch those pushrods, they flex far too much. A friend has the larger model and he had problems with the tail fluttering because of this. Also his plane had almost NO downthrust causing his plane to pitch up violently when you throttled up. Make sure that there is at least 1-2 degrees of downthrust on the engine. |
They are out of stock. The CMPro seems to be a little nicer with plug in wings and fairings for the struts for a more finished look.
But both the one above and the CMPro are out of stock on Nitroplanes.com Here is the link to it: http://www.nitroplanes.com/cmcearf46enp.html |
I can tell you it's a beautiful model. I am on the final stages of assembly and it looks much better than any other i have seen. I have a thread on mine here
http://www.rcuniverse.com/forum/m_6065502/tm.htm I will post more pictures later tonight maybe. I got mine from nitroplanes.com |
I keep checking ebay and the Marketplace here on RCU. I want one of these but Nitroplanes.com says 3-4 weeks to restock.
I cant believe the detail for under $150. |
| All times are GMT -8. The time now is 08:38 AM. |
