DPM Ultimate lower wing
I don't know if this is the correct forum, but I recently acquired a damaged Dave Patrick Models Ultimate 120 and it has a damaged lower wing. I am starting to repair but it may be a useless gester, as it is pretty bad. I am looking to buy a lower wing for this ARF.
I have had no luck in contacting DPM for buying that part. Thank You |
RE: DPM Ultimate lower wing
If you can't find a replacement, it shouldn't be too hard to build one from scratch. The ribs should be the same size as the Ultimate has a constant wing chord.
Thanks Biggs
Good luck.
| All times are GMT -8. The time now is 11:10 AM. |
