HELP! PLEASE!
I just got a Matt Chapman .46 CAP and I've installed all the servos except for the throttle servo. I got a JR sport standard ST47 I think. I cant get it to move the throttle all the way open even with full throw. I NEED HELP!
RE: HELP! PLEASE!
First thing to do is make sure your throttle trim on your tx is in center position. How is your Throttle rod attached to your servo? If it is with a t-clevis then loosen the t-clevis open your throttle to full open on tx and manually open carb to full open. You should then tighten the t-clevis with the carb full open. Try this and see it it works for you. I have a chapman same size with a 91 magnum and that was the way I got it to work with a little trimming on throttle. I had to use a throttle cable instead of a solid rod but the principal is the same. J D
RE: HELP! PLEASE!
you may also need a longer servo arm for more throw.
RE: HELP! PLEASE!
ORIGINAL: gjeffers you may also need a longer servo arm for more throw. |
| All times are GMT -8. The time now is 01:03 AM. |
