RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Cg for Edge 540 (https://www.rcuniverse.com/forum/arf-rtf-75/64525-cg-edge-540-a.html)
jemilheis 02-27-2002 09:15 PM
Cg for Edge 540
I have a Giant Scale Planes Edge 540 80". First of all the plane is a big piece of crap. I had to strip it down, reinforce, reglue bad joints, replade balsa stringers with spruce, and finally recover. Now I am in need of the proper CG for it.If anyone has any information, please let me know. Thank you Jim
mglavin 02-27-2002 09:47 PM
Cg for Edge 540
Jim
I do not have specificv knoweledge of the particular model, however the rule of thumb is 25% of the root chord.
This means if the wing is 12" leading edge to trailing edge at the center section that 3" from the LE would be a good starting place.
25% of 12" = 3"
This is wel proven figure and works well some guys use 30% as well.
Good luck
Jemo 02-28-2002 12:47 AM
Cg for Edge 540
Try this site, it has a cg calc
http://www.palosrc.com/instructors/cg.htm
jemilheis 03-05-2002 03:34 PM
CG
Thanks jemo, the cg calc works great.
Jemo 03-05-2002 03:39 PM
Cg for Edge 540
Yes it does, use MGalvins, starting points of 25% to 30% and you should come up with a good CG.
Johnny_Rebel 03-05-2002 04:45 PM
wheres the gsplanes advice?
I'm surprised the gsplanes guys haven't responded- They are very noledgeable about there planes. I think they test fly all there models after putting each one together and making sure everything is as advertised. Mabye you should try emailing them.......
OUTCAST 03-05-2002 08:03 PM
Cg for Edge 540
Just as a point of intrest the balance point is 25-30% of the mean aerodynamic chord not the wing root. You need to compensate for both wing taper and sweep. The palo site works well.
jemilheis 03-06-2002 02:08 AM
Cg for Edge 540
Jonny_Rebel, I have e-mailed and called them. All they tell me is that is 25% measured at the root. For some reason they won't give an exact number. The cg calc works great.
jemilheis 03-06-2002 02:14 AM
Cg for Edge 540
jemo, although the leading edge of the wing is straight, do you take in account that the trailing edge is seept? Is that the number I should use for the sweep slot in the cg calc?
RC Extreme power 03-06-2002 04:00 AM
CG
The CG is 43/4" to 51/4" 5" is best from leading edge of wing
Milton
Jemo 03-06-2002 12:06 PM
Cg for Edge 540
You put zero in for the sweep (S). If the sweep is zero and the tip is smaller than the root, the trailing edge sweep is accounted for.
jemilheis 03-06-2002 03:43 PM
CG
Thanks guys, you have been alot of help. Jim
