RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   H9 P-51 C.g. ? (https://www.rcuniverse.com/forum/arf-rtf-75/646266-h9-p-51-c-g.html)
bigflyguy 03-24-2003 09:29 PM
H9 P-51 C.g. ?
I am just about done with my H9 P-51 ARF. I have a Saito .91 in the nose and used a lighter than stock engine mount. It appears as though it is somewhat tail-heavy even with the battery behind the firewall. This is checked without any fuel in the tank. H9 recommends 4.75 inches aft of the wing/fuse junction (most forward section of the wing center section). How far aft are you guys running your cg's? As it has a nose-over tendancy a slightly aft cg may help I have been told. I hate adding dead weight (and so far never have had to)...
toucano 03-24-2003 11:35 PM
H9 P-51 C.g. ?
I agree with the slightly aft CofG. Mine tips over 95% of the time. I should probably angle my landing gear forward. You threw out the stock retracts, right?
Where do you fly? I'm out at 107th.
Russmall 03-25-2003 01:05 AM
H9 P-51 C.g. ?
I started mine out with the CG set at 5 " back and it flies really nice. Only have 5 flights on it so far, but nose overs have not been a problem at all. And, inverted flight requires almost no elevator input for straight and level. I'm very pleased with it.........RS
bigflyguy 03-25-2003 02:17 AM
H9 P-51 C.g. ?
Toucano,
Yes, I got rid of the stock retracts and fitted a set of Robart 608's. I am flying out of Pratt's Wayne Woods - I got out for the first time this year yesterday and today with my TwinStar. Looking forward to flying the P-51! Thanks for the info.
