DP 330l
Can someone please let me know what the CG relly needs to be so the thing is not sooo..pitch senative??? Bob [email protected]
DP 330l
Do you have one flying now? What is your CG? Running any expo?
DP 330l
Mine is at 6" and it is VERY pitch sensitive. It just plain flies tail heavy at that CG. But, I am running some expo and just a little elevator throw on low rates and it is a blast! I would like to have mine in the 5 1/2" range but don't want to add the lead to get it there. I might eventually but I want to fly it some more. I have a zdz40 on it and it weighs 16lb. Great combo.
DP 330l
i am at 6 1/4 i am not pitch senstive.
I run the following for low rates 10 degress elevator, 25 rudder/20 degrees ailerons the other rate are 3d as follows: 40 degress elevator 40 degrees rudder 25 degrees of ailerons at this rate my plane still dives a little inverted, i will be moving the cg on back to achevie hands off inverted. As long as you are not banking and yanking the elevator stick 10 degress you will find will work with just about any aerobatic ship..... |
| All times are GMT -8. The time now is 12:07 AM. |
