Ultimate Bip Elevator linkage question,
My question is;
the seagull ultimate's elevator is two seperate panels. which would be the best route to take, link the two incoming control rods to 1 servo using a joining barrel, or use the 2 intended servos side by side in the tray and run a y-harness like on the wings.? or is there another option out there for this area.? thanks in adv. |
RE: Ultimate Bip Elevator linkage question,
Mine is setup as pictured in the manual. Two separate servos but mixed through the transmitter, No Y harness.
So far I am using the stock hardware and linkages and have had no problems with any of it. Only thing I changed on mine were the lower to upper wing aileron rods. I went with carbon tube and 2-56 ball links for a more rigid setup. |
I don't see the need to solder the two together. I use a pair of stock servos mixed in the radio. A "Y" harness would work just as well.
David |
| All times are GMT -8. The time now is 07:11 AM. |
