RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Full throttle climbs, why? (https://www.rcuniverse.com/forum/arf-rtf-75/68744-full-throttle-climbs-why.html)
cattrell 03-06-2002 03:15 AM
I am going to go with trim at full thottle and forget it......
Even though this is fun to read.........
I even went out and flew this afternoon just to study the situation, It may take further research. :D
microflight 03-06-2002 03:30 AM
here is the answer
Bang it on top 2 times and on the side 3 times, then pick it up on one end and drop it.
If that don't fix it, it's broke!
bobf46 03-06-2002 03:42 AM
And always remember, when at full throttle you're tongue must be on the left side of your mouth!!!
Weldo J Melvin 03-06-2002 03:55 AM
And to think, all this time I thought it was the right side of the mouth. Man, I learn something new every time I visit this place. :D :D
Weldo :)
Jazzy 03-06-2002 02:10 PM
The Crow, sorry about our goofing off. We like to have fun:D.
No harm intended.
If the CG is correct and the stab and wing are in their proper orientation, trim the model at your favorite flying speed. That way when you decrease throttle it will slowly descend. Add power and it will climb.
Trainers have a natural tendancy to climb. That is the way they are. You may want to consider moving up to a mid-wing or low-wing aerobatic trainer for a little more stable performance.
Years ago, my instructor, gave me a very important bit of advice: the KISS method. Keep It Simple Stupid! It works. The more you alter the way the canooter valve operates in relation to the kadutzit pin the more variables you throw into the equation and the greater the likelyhood of something going wrong. The frammish pin is a whole nother story.:D
Best of Luck,
Jeff
Weldo J Melvin 03-06-2002 05:46 PM
Nuff said,
I think it may be time to put this baby to rest......
Weldo
Champ-RCU 03-06-2002 07:40 PM
Taildraggers Right
Crow, listen to Taildragger! ir Knocker pilots rule. (What we rule is not clear, but once we find out -look out.) (Aeronca) Champ, Mark.
Check out a book called Stick and Rudder by a German fellow named Otto #### Having a senior moment here but that should get you in the ball park.
stevezero 03-06-2002 09:24 PM
tongue situation
Weldo, you just need to be flying inverted more, thats all
the crow 03-07-2002 12:49 AM
Fellas, thanks for all that advice.
As part of my check list, the CG's at exactly as the manual says. The only reason I notice this situation is I also have another trainer (RCM trainer 40) and it did not have that "problem". As far as this is inherent in a flat bottom wing, these two planes are both flat bottom winged.
I will try down thrust 1st and then up thrust.
After that, i'll start flying with my tongue in the left cheek to climb amd right cheek to descend. If that won;t fix the problem, i'll give it to my 11 year old son who flies better than I am :D
Again thanks for the input
magnum 03-07-2002 02:13 AM
The crow,
I just went thru this exercise on my bipe. With every throttle change the plane would climb. Everyone had a suggestion, but the thing I noticed was in level flight chopping the throttle created a MAJOR nose up attitude. It was a bear to fly and we almost crashed it on landing, everytime you backed off the throttle to flair, it would nose up!
Go by the trimming chart. Try chopping the throttle and seeing what the plane does.
I added 2 deg of upthrust and 2 more degress of right thrust and it was like having a new plane. The amount of down/upthrust and even right thrust will vary on each plane based on engine size, and also the prop. Changing props can change your thrust angles, however one or two sizes is hardly noticeable and not worth fooling with.
flyboy2 03-07-2002 03:03 AM
Forget about thrust and incidence angle. Any airplane in level flight has a specific speed and angle of attack. An increase in speed requires a lower angle of attack and a slower speed requires an increase in the angle of attack to maintain a constant level of flight. An increase in throttle at the same angel of attack for level flight will result in more lift and the climb you are experencing. To maintain level flight as you increase speed you must apply forward stick pressure(down elevator) and conversely you must apply back stick pressure(up elevator). If you have a programmable radio, you can program a throttle increase with a corresponding down elevator and thus level flight. This will require some experimentation as to how much elevator is needed. This is a rather simple explanation of a rather complex subject, but if you want a detailed explanation read Chapter 1 of Wolfgang Langewiesche's book Stick and Rudder.
Eagle Flyer 04-22-2002 01:40 AM
Prince America Hobby Star
Just put one up today. With a Saito 45 in it turning a 10x6 at 10,500. Balanced perfect with that engine with receiver and battery tucked behind fuel tank. Didn't have to touch the trims at all from initial settings! When throttled down to half it dropped altitude slowly. Put in a little up trim and it held level flight at the half throttle setting. It will fly upside down too. No sluggish reponse time and waiting for it to do it's thing. Lands like a -----cat. I would strongly recommend this for a trainer. And the constructional design gives it a lot more strength than a stanard balsa plane. Greeeeeeeaaaaaaaat plane. Need any more info email me at [email protected] Jim
elderair 04-22-2002 04:10 PM
Climb and trim
The definition of Angle of attack is THE ACUTE ANGLE BETWEEN THE CORD ANGLE OF AN AIRFOIL AND RELATIVE WIND. A flat bottom wing will normally have increased lift with increased speed given a constant angle of attack(the faster you go the higher you climb). If the C.G. is correct and the wing and horizontal stab are in harmony with one another then there is no reason to fight the trim with every throttle change when one could add down thrust. I dislike flying a trainer with a flat bottom wing when a semi or fully semetrical trainer will fly just as forgiving with the proper dihedral and wing load. Also doesn't have the trim issues associated with the flat bottom. Hobbico makes a great example of a trainer with a fully (or semi) semetrical wing which flies excellent and can be flown inverted as your skill progresses without adding full down elevator. Use an incedence meter and then try a few things that you have read here. Let us know what you finally decide worked for you. Every full scale pilot knows about the elevator controlling forward speed and the throttle controlling pitch. If you have any doubt of this try climbing and then chop the throttle. Bet the nose comes down. As modellers we know this as we set up a glide slope for landing our model and control the glide path with the throttle while keeping the elevator in a fixed position. Nothing wrong with trimming the plane to fly like you want it to fly though. Play around with it and learn a lot!!! Use the knowledge on your next plane. Remember when you use the Pattern trim chart that pattern planes are not flat bottom airfoil and it will show that too much down thrust will cause the plane to balloon when the throttle is chopped because of the up elevator trim used to counter it. Your flat bottow wing doesn't need the up trim to counter the down thrust because it generates the counter force itself and as speed bleeds off the lift decreases all by itself. My 2.5 cents worth.
OUTCAST 04-22-2002 05:58 PM
J%$#s f$#%&n C%@#$t..... ITS NORMAL !!!!!
I'm switchen to choppers
Dave Bowles 04-22-2002 07:23 PM
Another Option
Here is a Little cheater method I have used to counter Engine thrust and high speed climb, If you have a programable radio set upa mix between the throttle and elevator so you get a slight down elevator as you increase throttle, the same will work for engine torque as well, The will be a slight delay for the high speed mix untill the airplane comes up to speed.
When using down thrust or the mixer to counter a high speed climb be ready for a fairly sharp climb When you chop the throttle, the airplane will still be at speed .
If you want to know more about the use of wing angles and down thrust ask the Free Flight Guys, They use it exclusively to control climb and glide.
Hots_Flyer 04-22-2002 08:13 PM
Hey Outcast---Choppers change altitude with throttle changes too---LOL
HarryC 04-22-2002 09:36 PM
Originally posted by Wings
climb with power, and you control airspeed with the elevator, anyone with a pilots license can tell you that"
This will in fact happen under certain conditions such as MCA or during a landing when you are on "the back side of the power curve". Like our models, during normal flight conditions, the elevator is the primary control for altitude.
Sorry to disappoint so many of you, but the elevator is not the up and down control, it is the speed controller. Not just at MCA or during landing but in all flight. I fly full-size, all sorts from 1930s biplanes to military jets, and the rule of elevator to control speed is an absolute in all aircraft at all speeds in all flight phases. Power is the height controller. Of course you can make changes to height by pulling back on the stick if you have enough surplus speed but all you do is swap speed for height and the aircraft's energy does not change. I suggest that you hire a Tiger Moth and when it is trimmed in the cruise, try pulling gently back on the elevator. For about 2 seconds you gain a few feet, then the speed drops drastically and you start losing height. The more you pull back, the faster you go down. Even in a jet fighter the speed responds instantly to elevator, they just tend to have so much speed above stall in normal cruise that they it takes some time for the swap of all surplus speed into height to happen.
All aircraft from the tiniest free flight model to a B747 gain height as power is increased and lose height as power is decreased. It is written into the laws of nature. An object has an energy, it is only we humans that separate it into kinetic and potential energies for the sake of calculations. To increase height but keep the same speed, an object must have its energy increased and the only way to do this is to add power. Using ele will just leave the plane higher but slower and it must now descend back down to regain the same speed it started with!
What we seek to do is avoid the violent pitch change that some models have and downthrust helps this, but beyond that it is vital that all new beginners learn that to go up they increase power and to go down the reduce power, with the elevator being used to set the plane's attitude and hence its speed.
Harry
Flying Scotsman 04-22-2002 09:37 PM
Flying Manual
Maybe someone has already posted this website but there is no harm in posting it again.
http://www.monmouth.com/~jsd/how/
Interesting thread.
Steven
OUTCAST 04-22-2002 09:41 PM
Hey Hots, I thought helis went up with collective! OK thats it, I'm going fishing. :D :D
cajungent38 07-07-2003 09:45 PM
Most everyone here has a good point.
I fly full size also and I know that when you have the power to weight ratio as we do with R/C planes, you can throw the full size aerodynamics book away.
Only time I find this information helpful is on take-off and landing.
kentt7007 07-08-2003 12:03 PM
(scribbling on notepad) Ummmmmmm....what was the question again?
