Cap 232, 60size ARF
I will be getting this plane in the mail soon and I really need to know,
What Engine to put in the Bird, It says on the Box 80-902stroke and 90-1204 stroke :confused: If I go with a O.S. 91 Four stroke will it hover? If I go with an O.S. 91 2 stroke will it hover ? What Engine should I get? Or do I need something more? :confused: I really like this plane but I want it to be able to do what I want. Should I go with light? What should I do? :rolleyes: |
Cap 232, 60size ARF
This is the Kangke, correct?
Cap 232, 60size ARF
One more thing,
Does anyone know of a company that will make logo decals for R.C. Planes? And Also , what is the best way to keep the Cap from tip stalling? |
Cap 232, 60size ARF
And Yes FlyFalcons, Its the Kankge Cap 232
Cap 232, 60size ARF
Originally posted by Paul Terry And Also , what is the best way to keep the Cap from tip stalling? |
Cap 232, 60size ARF
The best way to keep a cap from tip stalling or snapping out or whatever you want to call it is not to reach and grab a stick full of elevator.
Had an OS 91 FX on mine with a perry pump, one fine plane till somebody turned another radio on, or at least thats what I think caused it. Never tried to hover it much, but it had enough power to pull out. Ed M. |
Cap 232, 60size ARF
That Info really helps, Thanks guys,
I am really excited about getting this plane. Is there any things you did different on your Caps to help any thing? Or do they pretty much have all the bugs out? |
| All times are GMT -8. The time now is 12:27 AM. |
