Dragon Lady, enough engine?
Hey all,
Just picked up an older Dragon Lady ARC kit. Here's my question. I purchased it off ebay not seeing the required engine specs. The required specs are .91 to 1.6 Four Stroke. Will a YS .91 be sufficent or should I opt for a larger 1.10 or 1.40. Any thought or comments are welcome. Thanks, Scott J. Wolke |
It'll be plenty. I built the ARC. You can expect it to weight 9.5 to 10.5 lbs. I have a 120 2 stroke in it and I think the YS91 would be a good match unless you want vertical excell out of a hover.
Denis |
It is a easy flyer not a 3d aerobatic plane. I'm finishing mine now and I'm putting a YS.91 in.
Since you'll most likely beat me in the air, let me know how it flies with that engine!!
Scott J .Wolke |
I've had a Model Tech for years. Great airplane.
OS 1.2 4 stroke seems perfect. My buddy liked flying it so much bought the plane and tried several engines. OS 1.2 Surpass is perfect. |
RE: Dragon Lady, enough engine?
NeoGenesis, would you by any chance still have the instructions for the Dragon Lady ARC? I just acquired one, but no instructions.
| All times are GMT -8. The time now is 02:44 AM. |
