SIG FOUR STAR 60
I just purchased a new Four Star 60, already assembled, and with no MANUAL!!!!!!!!
I can't find one on-line to download. Any suggestions????? I need to find the proper CG for it before I attempt to fly. Any help would be greatly appreciated |
RE: SIG FOUR STAR 60
CG right at the main spar will do the trick.
I recently saw an article that has CG at 3 5/8" behind wing leading edge.
BobbyG |
The CG is 3 5/8" back from the leading edge stated from the manul. You can go to Tower Hobbies web page and they have it listed their if you go to the 4* 60. It will also give you the throw rates to set it up as well.
Thanks a lot. With your help. I found what I was looking for.
mbrennan1 I like to do it right the first time |
It flies great balanced on the main spar
| All times are GMT -8. The time now is 04:23 AM. |
