RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Fun Tiger (https://www.rcuniverse.com/forum/arf-rtf-75/746992-fun-tiger.html)
Flyin' fast 05-05-2003 06:58 PM
Fun Tiger
Help!!!
Yesterday at the air field, I bought a plane called the fun Tiger G-200. Made by Thunder Tiger. If anyone has every owned this plane, tell me all the pros. and cons. about this.
Flyfalcons 05-05-2003 07:08 PM
Fun Tiger
It's a nice flying plane, not the best as far as profiles go because it is a little heavy and snaps at low speeds with too much elevator input. I used mine for quite a while, learned how to hover and do rollers with it. Control throws are all you can get, balance it on the CG, and use a strong 46 ball bearing engine for good performance. I ended up dorking mine and gave it to someone at the field, who fixed it and now has a 60 for power. Definitely a strong performer now! The wing and tail wood are a little soft so be careful with the tail. The wing will take the abuse of nearly anything you can throw at it. Don't fly it too fast though; I fluttered an elevator half off after a particularly impressive full power inverted spin. I landed it and built another elevator and flew it for a while longer.
bigfishman 05-05-2003 11:47 PM
Fun Tiger
i have the same one only the extra version
only difference is color
i have a 46 fx on mine and it is a great plane
will do just about anything u want. vertical is great
hovering is not the best. i think it is very fun but dont put a big 61 in it too heavy and will flutter
very slow flying plane dont fly it fast the alierons will flutter
tyler
krayzc-RCU 05-06-2003 12:04 AM
Fun Tiger
os 91 on mine running a 14 x 6 apc.....
bigfishman 05-06-2003 12:55 AM
Fun Tiger
thats alot of power
how does that thing fly with the 91 on it
tyler
krayzc-RCU 05-06-2003 01:37 AM
Fun Tiger
6 oz tank and 15 minutes flights i am very easy on the throttle full on 1-2 uplines per flight. i use the power for hovering as i keep it very low and like the pull out power. i have my rudder and elevator servo mounted in the fuse as this was ARC version. It a good knock around fun fly but i perfer the morris kits i have over this one but i like my fun flys on the cloudy days....
