Wing servos
How would you change from a single servo to dual servos in a foam wing? What I mean is, what do you need to do to mount the servo in a foam wing, ie, how would you do the mount?
Thanks. |
RE: Wing servos
Just epoxy a plywood plate to each end to screw the servos into
RE: Wing servos
I would say, first dig a hole in the foam for the servo, then the plywood at ech end.
RE: Wing servos
Ok, thanks, I was'nt sure.
| All times are GMT -8. The time now is 07:09 PM. |
