CMP Katana-S 140
I have just purchased a CMP Katana-S 140 and was going to put a SPE 40 in it. Anyone with the same plane and engine; I would like your comments of CG, Servos, and any suggestions for this set up. Thanks in advance!
RE: CMP Katana-S 140
Dreamin
I have this plane but I am running a Saito 180, turning an 18x8w prop. With this motor I had to add 14 oz of weight to the nose of the plane. Thats after moving all the servo's to the center of the plane. With the recommended throws on the elevator this plane will snap hard. My high rates are set just above recommended lows, just be carefull and be ready. I called Cmp(nitro models) to ask for there imput and all I could get out of them is this plane is good... |
| All times are GMT -8. The time now is 05:59 AM. |
