Modeltech Magic 3d questions.
I was wondering what kind of servos would be good on this plane (i like futaba). Should I get a mini servo for the throttle or is a standard small enough to fit in it. Also what rx should I get (I have a futaba 6xas if that helps at all) , I heard ppl having problems with fitting their rx in. Any other tips would be good too. thanks
-Jordan |
As long as you have adequate power (.46 or above), any servos will do. The Magic is not very weight sensitive and sandard servos will work just fine.
| All times are GMT -8. The time now is 09:58 PM. |
