VectorFlight Sukhoi
Anyone flying one of these? I have a 91fx that needs a home I had an older sukhoi and miss not haveing on in the fleet.
VectorFlight Sukhoi
Okay, the Vector Flight Sukhoi, 60" wing is definately a winner. I have been flying this exact plane with an OS .91 and it goes straight up. My empty weight is 7lb. 14oz's. Balance is where the plans call for. I modified my gear with some cable bracing and added a third screw to mount it. Also I added 2 washers under the trailing edge of the gear where it mounts to move the wheels forward abit which improves ground handling.
You will love this kit! Impressive when it arrives and goes together quickly if you want, I take my time and always modify an ARF whereever I see the need. This kit requires very little. I recommend this Sukhoi and personally I look forward to ordering another one of their kits. Great value for money spent. Feel free to e-mail me for further info. ([email protected]). Been flying from the mid 70's and have built many kits and ARF's. Dennis Swenson Ft. Lauderdale, Fla. |
VectorFlight Sukhoi
Is the sukhoi a two piece wing? is that a 91 2stroke you are running?
VectorFlight Sukhoi
Two piece wing that joins very easily with two spars for added strength. You don't have to worry about this wing, it's VERY strong.
The engine is an OS .91 2 cycle turning a 14X8. This is almost an unlimited vertical aircraft. You will love it. Any questions, e-mail me direct to; ([email protected]) |
VectorFlight Sukhoi
Yeah I know the planes well friends have the older style extras. The belly pan looks lame, did you glue your to your wing and just make it removable when you take the wing off?
VectorFlight Sukhoi
does anyone have a picture of this plane i'd love to see one !
VectorFlight Sukhoi
Go to: www.vectorflight.com
VectorFlight Sukhoi
oops sorry i ment like a reel picture you know with a motor thanks though red baron
VectorFlight Sukhoi
VectorFlight Sukhoi
To see a picture and a review of the extra, visit my website.
http://www.geistware.com/rcmodeling/...a300review.htm |
| All times are GMT -8. The time now is 03:14 AM. |
