Aeromaster question
I have a Giant Aeromaster ARC. My question has anyone else had this model?. I'm trying to figure out how much covering I need to order. I am going to use UltraCote to cover it. I'll be covering the most of it in white with some trim color I yet to have decided on.
Thanks for any help. |
RE: Aeromaster question
I have the Giant Aeromaster and it needed about 5 rolls of monocote as I recall. Nice flying plane. I used the Fuji 43 cc engine. If I did it all over again, I would probably use one of the 50cc engines I have read about in some of the engine forums. It flies fine, but I really like a lot of vertical. Enjoy the plane!
ORIGINAL: Lifer I have the Giant Aeromaster and it needed about 5 rolls of monocote as I recall. Nice flying plane. I used the Fuji 43 cc engine. If I did it all over again, I would probably use one of the 50cc engines I have read about in some of the engine forums. It flies fine, but I really like a lot of vertical. Enjoy the plane! I'm going to use a Brillille 360 (60cc) engine I have setting around for the power part. It will fit just fine according to my measurments. |
You will have a blast!
| All times are GMT -8. The time now is 11:35 AM. |
