quick aileron question
Im almost done my 4 star .40 i got but i don't have manual
I was wondering what angle to set my ailerons A parallel with the bottom of the wing B in between A and B C parallel with the top of the wing http://i160.photobucket.com/albums/t...ileronsjgp.jpg |
RE: quick aileron question
I’ve always set them between A and B. I think setting them either up or down can add additional lift on cretin aircraft. The 4* 40 is a great airplane with plenty of lift already. I have the venture 60 which is designed by the same guy and I set mine in the middle.
Others with more knowledge might chime in with reasons to do otherwise but I’ve never had a problem setting them in the middle. Good luck with the 4*! Jeff |
Is your wing a flat on the bottom ? A , is the way I set mine up btw. Bob |
The 4* is a nearly symmetrical airfoil. set a line from the leading edge of the wing to the trailing edge. Set the aileron along that line. Your example B most resembles that.
I set mine with an imagary line down the middle of the wing, that being a line from the middle of the front to the middle of the rear.
I've built a 4* 40 & 60. Set it in the middle & they will just about fly without you !!
In between A and B. :D
| All times are GMT -8. The time now is 08:18 AM. |
