RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   CMP GILES 202 40 size (https://www.rcuniverse.com/forum/arf-rtf-75/8783334-cmp-giles-202-40-size.html)
jeffreyheslop 05-19-2009 09:39 PM
hi i have just bought a cmp giles 202 40 size, used. but it didn't come with any manual http://www.rcuniverse.com/forum/js/f...ngry_smile.gifso i have a few questions if anyone can help me out.
where can i get a manual, that would be the best. the fuel tank, the guy that had it before me mounted it to the wing under teh cannopy. the only problem is that it is too far from the engine, not enought presure to keep the fuel flowing during vertical flight. the servo for the throttle was a prob but my friend helped me out by making a brase for the servo and mounting it just above teh front of the wing under the cannopy.
where is the c of g we are not sure where that is about, when were flying her she seems to be a bit tail heavy.
and the engine thrust line, should it be facing down a bit?
if anyone could hepl me with these few questions i would be most greatful
thankyou for you time
http://image2-5.rcuniverse.com/e1//m...620-0-3615.jpg
Sourkraut 05-19-2009 10:22 PM
RE: CMP GILES 202 40 size
1 Attachment(s)
Hi.... I have the exact same plane (my second one to be exact) but that is another story.http://www.rcuniverse.com/forum/js/f...wink_smile.gifI have the tank tucked into the front of the fuselage right behind the firewall. I am not to sure at this moment on the CG as I don't have my manual in front of me right now, but I can get you any info on it that you would like on Thursday night when I get back home. I also have the throttle servo installed into the compartment beneath the tank ( there should be a small hatch on the bottom front of the fuse).
Both mine are, and were,terriffic flying planes when balanced correctly....it will land as light as a feather.
I am flying both mine without the cowl on as I prefer the "Stick" look.
You can let me know if you want me to provide some info
Cheers
Curt
dudual 09-11-2011 09:29 AM
ORIGINAL: Sourkraut
Hi.... I have the exact same plane (my second one to be exact) but that is another story.[img][/img] I have the tank tucked into the front of the fuselage right behind the firewall. I am not to sure at this moment on the CG as I don't have my manual in front of me right now, but I can get you any info on it that you would like on Thursday night when I get back home. I also have the throttle servo installed into the compartment beneath the tank ( there should be a small hatch on the bottom front of the fuse).
Both mine are, and were, terriffic flying planes when balanced correctly....it will land as light as a feather.
I am flying both mine without the cowl on as I prefer the ''Stick'' look.
Cheers
Curt
hi !!
i have same plane
how do i connrct the wing to the body???
