Modeltech Magic Extra
Looking at the above plane, had a Weston UK Cougar 2000 which I lost to radio failure, but like the look of this as it looks more like a real plane.
What I wanna know, the engine I am looking at using is an OS 40 FP, will this be enough engine????? I bought the engine 2nd hand, and aren't sure if this is an FX or an LA equivalent engine?? If this isn't enough engine, could you recommend something that I can use the engine on??? (don't particularly want a standard magic) |
Use a OS 46FX or 50SX, TT46 pro, Saito 72, YS63 and if you like Magnums use a 46 size or larger. Any 46 size motor will haul this plane fine. 40 FP will not be up to par.
| All times are GMT -8. The time now is 06:35 PM. |
