RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   tank position,seagull pc-9 (https://www.rcuniverse.com/forum/arf-rtf-75/898480-tank-position-seagull-pc-9-a.html)
flyman1 06-26-2003 12:56 AM
HI I HAVE A SEAGULLPC-9 AND INSTALLED THE TANK AS PER INSTRUCTIONS.----THE TANK IS MUCH HIGHER THAN THE CARB.--
AND THE FUEL , LEAKES OUT DUE TO GRAVITY. HAS ANYONE HAD THAT PROBLEM? AND HOW DID YOU FIX IT?
THANKS
LEN
spooner 06-26-2003 10:53 PM
hi there flyman1. well i just finished mine and i took out the little tank that came with the plane and put in a little bigger one... and yes it did leak through the carb..i had to turn in the high end needle to get it to stop and it still runs fine (o.s. 46fx).. hopefully will get the maiden in on saturday.....spooner
flyman1 06-27-2003 12:44 AM
HI-JUSTGOTR
THANKS FOR THE REPLY, WHAT I DID WAS TAKE OUT THERE TANK PUT IN A GREAT PLANES ONE TOOK OUT THE DOWEL THAT SUPPORTS THE TANK, AND LOWER THE NEW TANK, ABOUT AN INCH ---I TEST RAN IT-----SEEM TO RUN FINE NO LEAKS HOPE TO TEST FLY SUNDAY. HOPE YOURS GO WELL.
LEN
spooner 06-27-2003 01:31 AM
cool, may the flying gods be with us this weekend....lol
