RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Hinge Tape (https://www.rcuniverse.com/forum/arf-rtf-75/8988479-hinge-tape.html)
dmurf 08-04-2009 04:36 AM
Hinge Tape
Hi guys,
Can you use clear covering {solarflm} to seal up the hinge line on a 50cc gas plane.
Damien
Zeeb 08-04-2009 08:49 AM
RE: Hinge Tape
I've seen guys post about using various types of tape for gap sealing, but don't really remember the brand names as I don't do it that way.
Depending on the coloring, I use either clear UltraCote (they call it transparent rather than clear) or I color match with UltraCote. I've also seen guys post about only doing one side, but I think that'll lead to accumulation of debris especially if you use tape, so I do both sides of the surface.
JMHO, YMMV.... ;)
opjose 08-04-2009 10:29 AM
RE: Hinge Tape
Yes you can.
But remember : Sealing a hinge DOES NOT stop flutter, nor affect the causes of flutter.
