Ultimate
What is the differnce between the 50cc 10-300 ultimate from wildhare and the 50cc 20-300 from aeroworks? im not wondering brand wise, im really more interested in the 10-300 and 20-300 part, whats the difference there. Can anyone help?
RE: Ultimate
I have the last WH Ultimate, so unless Tom changed his mind the biggest differance is you can buy the AeroWorks one. I see that the elevator servos are in the stab of the AW, they are in the fuse of the WH.
RE: Ultimate
oh. the last one, hmm. ok. AW it is i guess. cant find any other brands in its approx size besides wild hare that does not have a flat stab. I absolutly dont want a flat stab airplane ever again. thanks
RE: Ultimate
Wildhare:
Wing span 64" 70" rudder to spinner Approx. 17 lbs. 1450 sq. in. 50cc-60cc gas Aeroworks: Wing Span 68 inches. Wing Area 1666 sq. in. Fuse Length (Rudder to Front of Spinner) 78.5" Cowl Width 10" Weight 17.5 to 18.5 lbs Engine 50cc The Aeroworks is slightly larger. Also being a longer plane it flies IMAC very well. Tom's Wild Hare is an amesome plane, but as stated no longer available. I have the Aeroworks and absolutely love it. It ended up being 18.5 lbs but does have 1666 sq" of wing area. I will definately recommend a motor a bit bigger than 50cc. Especially if you are at any altitude. I am at about 960 ft and am using an MT57 with a Xoar 23x8. Works good. |
RE: Ultimate
The 10-300 is a single place aircraft, and the 20-300 is a 2 place plane.
| All times are GMT -8. The time now is 09:20 PM. |
