Removing glue from covering
Whats the best method to remove that white CA glue residue from plastic covering? I did some gluing around the covering on an ARF and now I've got that whitish CA glue haze that needs cleaning up.
Thanks. |
RE: Removing glue from covering
Hobby Peoples "Kwik de-bonder" works for me on Monokote. You also might try acetone.
Here's the linkhttp://www.hobbypeople.net/gallery/887545.asp<br type="_moz" /> |
1 Attachment(s)
ORIGINAL: bryris Whats the best method to remove that white CA glue residue from plastic covering? I did some gluing around the covering on an ARF and now I've got that whitish CA glue haze that needs cleaning up. Thanks. |
You can also use trim Kote solvent.
just borrow your wifes nail polish remover but make sure it has acetone in it
ORIGINAL: turboratt just borrow your wifes nail polish remover but make sure it has acetone in it |
| All times are GMT -8. The time now is 02:53 AM. |
