RCU Forums
-   ARF or RTF (https://www.rcuniverse.com/forum/arf-rtf-75/)
-   -   Wing is too long! (https://www.rcuniverse.com/forum/arf-rtf-75/9687352-wing-too-long.html)
Desertlakesflying 05-01-2010 12:37 PM
RE: Wing is too long!
Looked at the manual...that wing idea should work great.
Hey how much are these going for?
Have a buddy going through a rough time trying to keep his business open with all these stupid politicians in Washington trying to kill small business, and sold his planes to pay some bills.
Desertlakesflying 05-05-2010 10:27 AM
Did you try it out yet? How did it work?
Sourkraut 05-05-2010 10:47 AM
1 Attachment(s)
I had the same problem with my Great Planes Cub with the one piece 81" wing. It was such a pain to haul around, that I hardly ever flew it anymore and I almost sold the plane as a result.
SO....Last winter I decided to "CLIP" the wings and I am sure glad I did. Now the wing is still one piece but only 68" long. I can now haul it with ease and it still flies fantastic and is way more aerobatic to boot.
I removed 2 bays from each wingtip to accomplish this but still used the original wingtips.
It was an easy one day mod and I am exstatic with the results.
Where there is a will.... there is a way!!
Good luck
Curt
mallen 05-05-2010 11:33 AM
Hey Curt,
Thanks for the pic's and it looks good! If I do decide to clip it, I'm going to do it the way you did. But I think I'm still going to keep it two piece either way. By the way, which engine are you using? I'm going with a four stroke in mine but not sure if I should put a 54 or 75 in it. I'm sure the 54 would be fine but I would like to have some extra power and I'm wondering if the 75 will just be overkill and mostly wasted....????
And Cowboylifersaver, no, I haven't touched it yet....I have a few more projects I want to get done before I start on it.
Thanks!
Mark
ahicks 05-05-2010 11:48 AM
FWIW, I have a Great Planes version. When I was deciding on power, I was thinking of how it might fly on floats? I went with an Enya 80 I had because of that. A little bit much for normal flying (flies great using no more than 1/2), but absolutely perfect choice when on floats.....
Sourkraut 05-05-2010 11:57 AM
ORIGINAL: mallen
Hey Curt,
Thanks!
Mark
Five years ago when I bought this plane new, I had a NIB OS .46AX 2 stroke laying around so that is what is in there along with a Pitts muffler. It had tons of power when it was an 81", but now that I clipped the wings, I find myself wanting just a little more power for some extreme non-scale aerobatics (trying to make a 3D machine out of it.. ha ha). The .46AX still flies it fine though but I do have an OS .61 4 stroke that I have been pondering putting in the Cub for a little more grunt and better sound. I also have a TT .91 4 stroke but that may be a little extreme for my Cubby.
I would probably go with a 72 size 4 stroke. It would be a great combo for that airframe and would work well with floats. A .91 is slight overkill... but hey... whatever floats your boat!!
Cheers
Curt
Iflyglow 05-05-2010 12:38 PM
Perfect time to consider a "Clipped Wing" modification like mentioned above.
